[gdal-dev] Converting coordinate systems(gdalwarp)
Joaquim Luis jluis at ualg.pt
Sat Feb 2 12:48:02 EST 2008
Omkaranathan wrote:
> I am using Virtual Planet Builder (
> http://www.openscenegraph.org/projects/VirtualPlanetBuilder ) from
> Openscenegraph to convert into osg format and view in its viewer.
> The same file works properly if I am directly using it. But after
> conversion I am facing the problem.
Well, I don't know that one (there are so many now).
Can you make available to us a small example file?
J. Luis
