[gdal-dev] Win32 Default Build Options
Lucena, Ivan
ivan.lucena at pmldnet.com
Mon Feb 4 15:48:48 EST 2008
Frank,
I tested the GDAL build process on VC8 (VS2005) and all went well, but
with no "/GR", if that was what you expected.
Example:
cl /nologo /MD /EHsc /Ox /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DE PRECATE /DNDEBUG -I..\..\port -I..\..\ogr
-I..\..\gcore -I..\..\alg /c bmpdataset.cpp
I will check the other issues as they come along my way.
I have a suggestion, I believe that most of us usually place all the
FOSS projects in the same root folder, so it should be interesting to
have a variable for that on nmake.opt, like:
DEV_HOME = C:\FOSS\
So, in all those place with "C:/warmerda" we should have $(DEV_HOME)
instead:
C:\FOSS\gdal>grep warmerda nmake.opt
File nmake.opt:
# $Id: nmake.opt 13667 2008-02-02 06:41:24Z warmerdam $
GDAL_HOME = "C:\warmerda\bld"
#TIFF_INC = -Ic:/warmerda/libtiff/libtiff
#TIFF_LIB = c:/warmerda/libtiff/libtiff/libtiff_i.lib
#GEOTIFF_INC = -Ic:/warmerda/libgeotiff -Ic:/warmerda/libgeotiff/libxtiff
#GEOTIFF_LIB = C:/warmerda/libgeotiff/geotiff_i.lib
#ECWDIR = C:\warmerda\libecwj2-3.3
#DWGDIRECT=C:\warmerda\DWGdirect
#OGDIDIR = D:\warmerda\iii\devdir
#XERCES_DIR = c:\warmerda\supportlibs\xerces-c_2_6_0
#KAKDIR = D:\warmerda\jp2\kakadu
#HDF4_DIR = D:\warmerda\HDF41r5
#HDF5_DIR = c:\warmerda\supportlibs\hdf5\5-164-win
#SZIP_DIR = c:\warmerda\supportlibs\hdf5\szip20
#GEOS_DIR=C:/warmerda/geos
Not a big deal, just a suggestion.
Regards,
Ivan
Frank Warmerdam wrote:
> Folks,
> I spent some very frustrating hours trying to work out why the gsg (golden
> surfer binary) format wasn't working on win32. It turns out it used
> dynamic_cast and our default build options didn't include /GR so dynamic
> casts just didn't work. Grr.
> I have added /GR for Visual Studio .NET 2003 and earlier. I'm not clear
> whether it applies in VS.NET 2005 and later or not.
> I also changed the default builds option an optimized non-debug build. The
> debug builds are too quirky (special runtime requirements) and so I don't
> feel they are suitable as a default.
> But what I would really like to do is remove /MDd in favor of /MD for debug
> builds. /MDd means we are building against the debug CRT - something I
> have
> very rarely felt any need for. I believe it is contrary to MS's EULA to
> redistribute the debug CRT so the binaries are not very useful for reuse.
> And it is hell mixing /MDd and /MD stuff. Can someone remind me how /MDd
> got added in nmake.opt? I don't recall a discussion of the issue.
> PS. /D_DEBUG apparently triggers a dependency on the debug CRT too, but
> only in ATL code (for us this is only the stuff in the vb6 directory. Boy,
> did I swear a blue streak trying to work that out!
> PPS. I'm not really so thrilled with all !IFDEF's in nmake.opt. It is
> interfering with the "essential simplicity" of it in my opinion.
> Best regards,
