[gdal-dev] OGR and VPF
Christopher Barker Chris.Barker at noaa.gov
Mon Feb 4 20:32:45 EST 2008
Frank Warmerdam wrote:
 >> but some archived emails lead me to believe that maybe the OGDI
Vectors format was somehow related.
 > OGDI is indeed the key.  You need to build OGDI which is *another*
 > multiformat geospatial library, then build GDAL/OGR with OGDI support
 > and then you can read VPF.
I'm running the Kyng Chaos build, which appears to have OGDI support,
but I can't figure out what file to point ogrinfo at. I downloaded a
chart (or thought I did), and got a zip file that had a dir in it named
"DNC26". in there is:
COA26A DHT    LAT
in the COA26A dir is:
CAT         ECR         HYD         LHT         LINEAGE.DOC POR
CUL         ENV         IWY         LIBREF      NAV         REL
DQY         GRT         LCR         LIM         OBS         TILEREF
and a bunch of stuff in those dirs -- I'm lost!
Maybe I didn't actually download a chart!
I'll poke at it more, but if you have any suggestions, I'm all ears!
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
