[gdal-dev] Win32 Default Build Options
Lucena, Ivan
ivan.lucena at pmldnet.com
Mon Feb 4 21:09:51 EST 2008
Frank,
Frank Warmerdam wrote:
> The problem with the GSG driver does not manifest at built time (except
> as nasty warnings). It only comes up at runtime. So either check the
> warnings carefull for stuff in the gdal/frmts/gsg directory or actually
> try running "gdalinfo -mm " against the autotest/gdrivers/gsg_binary.grd
> file.
No warming compilation on:
C:\Dev\gdal\frmts\gsg>nmake -f makefile.vc clean
Microsoft (R) Program Maintenance Utility Version 8.00.50727.762
Copyright (C) Microsoft Corporation. All rights reserved.
cl /nologo /MD /EHsc /Ox
/D_CRT_SECURE_NO_DEPRECATE/D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG
-I..\..\port -I..\..\ogr -I..\..\gcore -I..\..\alg /c gsagdataset.cpp
gsagdataset.cpp
-I..\..\port -I..\..\ogr -I..\..\gcore -I..\..\alg /c gsbgdataset.cpp
gsbgdataset.cpp
-I..\..\port -I..\..\ogr -I..\..\gcore -I..\..\alg /c gs7bgdataset.cpp
gs7bgdataset.cpp
xcopy /D /Y *.obj ..\o
C:gs7bgdataset.obj
C:gsagdataset.obj
C:gsbgdataset.obj
3 File(s) copied
Or linkage:
C:\Dev\gdal\frmts\gsg>cd ..\..
C:\Dev\gdal>nmake -f makefile.vc
lib /nologo /out:gdal.lib port\*.obj gcore\*.obj alg\*.obj
frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib
vb6\vb6_support.obj
ogrsf_frmts.lib(parsexsd.obj) : *warning LNK4221: no public symbols
found; archive member will be inaccessible*
link /nologo /dll /debug /INCLUDE:_OGRFeatureStylePuller
/INCLUDE:_OSRValidate /INCLUDE:_OPTGetProjectionMethods
/INCLUDE:_OGR_G_GetPointCount /INCLUDE:_OGRRegisterAll
/INCLUDE:_GDALSimpleImageWarp at 36 /INCLUDE:_GDALReprojectImage at 48
/INCLUDE:_GDALComputeMedianCutPCT at 32 /INCLUDE:_GDALDitherRGB2PCT at 28
/INCLUDE:_OCTNewCoordinateTransformation at 8
/INCLUDE:_vbSafeArrayToPtr at 16port\*.obj gcore\*.obj alg\*.obj
vb6\vb6_support.obj odbc32.lib odbccp32.lib user32.lib gcore\Version.res
/out:gdal16dev.dll /implib:gdal_i.lib
LINK : gdal16dev.dll not found or not built by the last incremental
link; performing full link
And everything looks good at runtime:
C:\Dev\gdal_autotest\gdrivers\data>gdalinfo -mm gsg_binary.grd
Driver: GSBG/Golden Software Binary Grid (.grd)
Files: gsg_binary.grd
Size is 20, 20
Coordinate System is `'
Origin = (440720.000000000000000,3751320.000000000000000)
Pixel Size = (60.000000000000000,-60.000000000000000)
Corner Coordinates:
Upper Left ( 440720.000, 3751320.000)
Lower Left ( 440720.000, 3750120.000)
Upper Right ( 441920.000, 3751320.000)
Lower Right ( 441920.000, 3750120.000)
Center ( 441320.000, 3750720.000)
Band 1 Block=20x1 Type=Float32, ColorInterp=Undefined
Min=74.000 Max=255.000 Computed Min/Max=74.000,255.000
NoData Value=1.701410009187828e+038
I will keep my yes on the /MD vs /MDd stuff but I believe you are right,
We don't need it even when we are really debugging.
Best regards,
Ivan
