[gdal-dev] gdaltindex invalid shapefile
Oliver Ishmael Oliver.Ishmael at broads-authority.gov.uk
Tue Feb 5 06:19:12 EST 2008
Hello,
I am trying to use gdaltindex to create a raster tile index for a series
of aerial photos.
C:\Program Files\FWTools2.0.6\bin>gdaltindex c:\2006\2006.shp
c:\2006\*.ecw
ERROR 4: Unable to open c:\2006\2006.shp or c:\2006\2006.SHP.
Creating new index file...
The resulting dbf of the shapefile has a 'location' field showing the
location of all the ecw files. This is it. It seems to be missing the
XMIN, YMIN, XMAX, YMAX fields and consequently ArcGIS is unable to load
the resulting 2006.shp
Using gdalinfo -stats I could manually enter this information but it
would take quite a while. So I just wanted to check that I'm doing
everything correctly?
Many thanks
Olly
If you have received this email in error, please delete it immediately and notify the sender. This email may contain confidential information and may be legally privileged or prohibited from disclosure and unauthorised use. If you are not the intended recipient, you must not copy, distribute or rely on it.
As email is not a 100% secure communications medium we advise you to check that messages and attachments are virus-free before opening them. We cannot accept liability for any damage that you sustain as a result of software viruses. We reserve the right to read and monitor any email or attachment entering or leaving our systems without prior notice. Opinions expressed in this email are not necessarily endorsed by the Broads Authority unless otherwise specifically stated.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080205/eb6ca40c/attachment.html
