[gdal-dev] Re: help needed with image creation
WolfgangZ wollez at gmx.net
Wed Feb 6 07:58:38 EST 2008
Frank Warmerdam schrieb:
> Wolfgang wrote:
>> Hi,
>> I want to create some images where I set the pixel values manually.
>> The values are Floats that need to be mapped finally to a color map.
>> I'm not really a skilled programmer but I've managed to get a first
>> idea how to do it (in python):
>> from osgeo import gdal
>> import numpy as Numeric
>> format = "GTiff"
>> driver = gdal.GetDriverByName( format )
>> dst_filename='test.tif'
>> dst_ds = driver.Create( dst_filename, 3, 2, 1, gdal.GDT_Float32 )
>> raster=Numeric.array([[ 1.,  200.5 ,  3. ],[ 256. ,  5. ,  60. ]])
>> dst_ds.GetRasterBand(1).WriteArray( raster )
>> What I don't understand is how to create/define a color map so that
>> the result looks better? I also suppose that it is not the best to
>> create float tiffs as not so many applications will support that type.
>> It would help me much if anybody could show me the steps needed to do
>> the task.
>> I'm sorry if this looks too easy for skilled programmers, but I'm
>> completely new to program graphics (with GDAL) and I still don't have
>> the overview over all GDAL functions.
> Wolfgang,
> You can't generally assign a palette to floating point geotiff files.
> There is no way for applications to understand how to apply it.
> Generally speaking, in GeoTIFF, you either offer the raw floating point
> science data, or you offer a version of it is that been prescaled to
> integers (usually 0 to 255) with a colormap.
> I'd add that it is very common for folks to distribute raw science
> data in floating point, and for the decision on a colormap to be
> applied being made by the user in the viewing application.
> Best regards,
Frank,
thanks for your answer! I recalculate the floats to a color manually, I
just thought that there would be somewhere a convenience function to do
that.
Many thanks
Wolfgang
