[gdal-dev] Unexpected value for TARGET creation option
Thu Feb 7 11:20:52 EST 2008
Jean-Claude Repetto wrote:
> Hello,
> I have just upgraded from GDAL 1.4.2 to GDAL 1.5.0, and now I have an
> error message when creating an ECW file :
> gdal_translate -of ECW -co TARGET=94% -co DATUM=NTF -co PROJ=LM1FRA2D
> -a_ullr 970000 1860000 980000 1850000 MAP.png MAP.ecw
> Input file size is 4000, 4000
> Warning 6: '94%' is an unexpected value for TARGET creation option of
> type float.
> I have tested some variants :
> -co TARGET=94
> -co TARGET=0.94
> -co "TARGET=94%"
> All are giving the same message.
> What is the right syntax ?
Jean-Claude,
I'm surprised.  I would have expected TARGET=94 or TARGET=0.94 to be accepted.
The "%" is improper and should not be included.  However, I tried this and
I see the same behavior you do. I have filed a ticket on this issue and it
should be fixed by 1.5.1. In the meantime you can just ignore this warning.
   http://trac.osgeo.org/gdal/ticket/2204
The validation of creation options is new in GDAL 1.5.0.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
