[gdal-dev] OGR shapefile problems
Dane Springmeyer blake at hailmail.net
Sat Feb 9 18:10:48 EST 2008
Hi John.
I am running GDAL 1.5.0 built from source and from Kyngesburye. Both
are able to "ogrinfo -al" both of the nv shapefiles you posted
without a problem.
What errors are you getting?
I am still on OS X 10.4.11, having not dove into the leopard world
yet. So, perhaps the problem is 10.5 specific.
cheers,
Dane
On Feb 9, 2008, at 2:31 PM, John C. Tull wrote:
> Hello All,
> I am running into problems with a shapefile using GDAL 1.5 binaries
> compiled by William Kyngesburye for OS X Leopard. We are trying to
> see if the problem is a GDAL 1.5 issue, or if it is something OS X
> related.
> The file reads properly using pre 1.5 GDAL binaries on OS X and
> Ubuntu. I did not have a 1.5 binary on my Ubuntu vm to test. I used
> 'ogrinfo -al' on the file.
> If anyone cares to take a look, I have placed the problem file
> online. You can download the landowner shapefile from http://homepage
> .mac.com/jctull/
> Thank you,
> John Tull_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
