[gdal-dev] OGR shapefile problems
William Kyngesburye
woklist at kyngchaos.com
Sat Feb 9 20:06:16 EST 2008
Yep, works for my framework on OSX. Thanks Evan.
On Feb 9, 2008, at 6:18 PM, Dane Springmeyer wrote:
> Ya, thanks John.
> I Just checked out and confirmed that EVEN's commit (obviously)
> fixed what you spotted.
> Ogr built from svn co after 2:59 pm reads `NV_Landowner_200711.shp'
> all the way through to FID 22810.
> dane
> On Feb 9, 2008, at 4:05 PM, John C. Tull wrote:
>> Thank you Even and others for having a look, and for the quick fix.
>> I'm glad to have helped uncover a small bug.
>> Cheers,
>> John
>> On Feb 9, 2008, at 3:05 PM, Even Rouault wrote:
>>> I could reproduce a problem with your file on GDAL trunk and
>>> branches/1.5. It
>>> is not MAC OS X specific.
>>> The issue was the polygon feature whose FID = 22734, with nParts
>>> == 0.
>>> Fixed in trunk in r13744 and in branches/1.5 in r13755
>>> Best regards
>>> Le Saturday 09 February 2008 23:31:57 John C. Tull, vous avez
>>> écrit :
>>>> Hello All,
>>>> I am running into problems with a shapefile using GDAL 1.5 binaries
>>>> compiled by William Kyngesburye for OS X Leopard. We are trying
>>>> to see
>>>> if the problem is a GDAL 1.5 issue, or if it is something OS X
>>>> related.
>>>> The file reads properly using pre 1.5 GDAL binaries on OS X and
>>>> Ubuntu. I did not have a 1.5 binary on my Ubuntu vm to test. I used
>>>> 'ogrinfo -al' on the file.
>>>> If anyone cares to take a look, I have placed the problem file
>>>> online.
>>>> You can download the landowner shapefile from
>>>> http://homepage.mac.com/jctull/
>>>> Thank you,
>>>> John Tull_______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
