[gdal-dev] GDAL and NUTM17 NAD83 datasets.
Daniele Romagnoli dany.geotools at gmail.com
Tue Feb 12 09:16:18 EST 2008
Frank,
thanks for your reply.
I have already properly set the GDAL_DATA var :(. (And the cited file
ecw_cs.wkt is present there)
Here's why I investigated for a Proj4 responsability.
Which type of permissions problems do you think should be involved? (I'm
using Windows Vista and GDAL_DATA links to a simple folder C:\work\gdal...
As an instance I know that Vista may introduce some problems in several
circumstances when working with C:\ProgramFiles... Moreover I have disabled
User Account Control some months ago...)
Thanks a lot. I will narrow my search for the cause of the problem.
Regards,
Daniele
On Feb 12, 2008 3:04 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Daniele Romagnoli wrote:
> > Hi list,
> > During my tests, I noticed that when using my build of gdal (1.4.4 on
> > windows xp) I can't get a Coordinate System for some specific Datasets.
> > As an instance I used gdalinfo from fwtools 2.0.4 on a ECW file and I
> > obtained this Coordinate System (partial copy and paste).
> > Using "my" gdalinfo I obtain the classic empty string.
> > I guess this issue could be Proj4 related (although I'm not really sure
> > about this).
> > For this reason I surfed the mailing list and I downloaded the proj4
> > library, I set the PROJ_LIB linking the NAD folder and I added the DLL
> > in the path. (GDAL_DATA has been already set in the past)
> > Anyway, the result is the same: empty coordinate system returned. As a
> > parallel experiment, I also tried statically linking the library with
> > the same result.
> > Is there some additional operations which fwtools based gdalinfo
> performs?
> > I'm surely wrong somewhere :)
> > Any help would be greatly appreciated.
> Daniele,
> GDAL needs to find the ecw_cs.wkt dictionary file to lookup ECW coordinate
> system names.  This is normally found via the GDAL_DATA pointer.  You
> mention
> you have this set, but I am suspecting it is set improperly or perhaps
> there
> is some related sort of error (permissions?).
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax:     +39 0584983027
mob:   +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080212/fd220aea/attachment.html
