[gdal-dev] gdalwarp rather than gdal_translate
Diana Esch-Mosher desch-mosher at lanl.gov
Tue Feb 12 12:39:15 EST 2008
I looked at gdalwarp and I see where it checks to see if the destination
file exists, if so then it reads the TargetSRS from that dataset. So I
should pre-create to the target size that I am requesting in gdalwarp? I
have no problem in python  pre-creating the file, copying the metadata,
geotransform, and projection data ... anything else I should copy? Then
I just call gdalwarp as gdalwarp -rcs -ts x y -of  NITF (or any other
-of  I want).
Diana
Frank Warmerdam wrote:
> Diana Esch-Mosher wrote:
>> I have a NITF file that I would like to resample using the more
>> sophisticated interpolation techniques of gdalwarp (-rcs). I do not
>> want the file to change in way other than size, I do not want to
>> transform/reproject/warp etc. When I specified gdalwarp -rcs -ts x y
>> -of GTiff it transformed the file in a North up. How do I specify to
>> not do anything other than resample?
> Diana,
> Currently gdalwarp does not support producing output files with
> georeferencing
> based on a GCPs.  You can write a file with a non-north up
> geotransform but
> only by pre-creating the file replicating the input geotransform which
> is not
> really practical from the commandline.
> > Is it possible to specify -of NITF? I
>> tried this using 114 and got errors. Do I need 115 for NITF?
> gdalwarp should support creating NITF files.
> When you refer to 114 and 115 are you meaning GDAL/OGR 1.1.4 and 1.1.5?
> Those are ancient!
> Best regards,
