[gdal-dev] gdalwarp rather than gdal_translate
Diana Esch-Mosher desch-mosher at lanl.gov
Thu Feb 14 15:55:22 EST 2008
Frank,
Well, this isn't quite doing what I thought. It is no longer
transforming the file (yeah!)  but is not resampling to the new size. If
I give it a new size, say slightly smaller (I'm trying to resample to a
common GSD), then it just crops the image to the new smaller size,
rather than downsizing. FYI, I'm using 1.3.2.0 ..... is that a problem?
Same goes for making a larger image, it is not resampling to a larger
size, and additionally it is washing it out.
Thanks,
Diana
Frank Warmerdam wrote:
> Diana Esch-Mosher wrote:
>> I looked at gdalwarp and I see where it checks to see if the
>> destination file exists, if so then it reads the TargetSRS from that
>> dataset. So I should pre-create to the target size that I am
>> requesting in gdalwarp? I have no problem in python  pre-creating the
>> file, copying the metadata, geotransform, and projection data ...
>> anything else I should copy? Then I just call gdalwarp as gdalwarp
>> -rcs -ts x y -of  NITF (or any other -of  I want).
> Diana,
> Right, except of course you don't specify parameters used to create the
> file (like -of or -ts).
> Best regards,
