[gdal-dev] basic raster math
Christopher Barker
Chris.Barker at noaa.gov
Thu Feb 14 16:50:43 EST 2008
Bobby Braswell wrote:
> Hi Greg, here's a basic example without GDAL (and thus with no
> projection info).
if you want to write it back out as a geotiff, GDAL will help there.
Take a look at some of the utilities that come with GDAL that are
written in Python -- essentially what you need to do is open the file,
then get the rasterband with:
numpy_array = band.ReadAsArray()
then do math with the numpy_arrays, then write it back out with
something like:
gdal.Band.WriteAsArray(numpy_array)
A note about the PIL code provided:
> # extract the data
> im1data = im.getdata()
> im2data = im.getdata()
> # get the dimensions
> dim = im1.size
> dim2 = im2.size
> # check dimensions
> if (dim != dim2):
> print "images are not the same size"
> sys.exit(0)
> # convert the data from image type to array type
> # (there are a lot of implications to this but for now it should do what
> you want)
> data1 = numpy.array(im1data).reshape(dim)
> data2 = numpy.array(im2data).reshape(dim)
All the above code can now be replaced with:
data1 = numpy.asarray(im1) (im1 is a PIL image object)
thanks to the "array interface"
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
