[gdal-dev] basic raster math
Christopher Barker
Chris.Barker at noaa.gov
Thu Feb 14 18:15:22 EST 2008
Greg Fiske wrote:
> placed in a namespace, it is now available as osgeo.gdal
> DeprecationWarning)
listen to that warning, and use:
from osgeo import gdal
>> >> gdal.Band.WriteAsArray(datadiff)
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> AttributeError: type object 'Band' has no attribute 'WriteAsArray'
gdal.Band is a class object -- you need to create a RasterBand object
(or use an existing one), and call WriteAsArray() on that. Sorry I can't
give you more help easily, so far I've needed read-only.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
