[gdal-dev] size limit in using gdal_translate
Limei Ran lran at unc.edu
Fri Feb 15 10:04:02 EST 2008
Hi Frank,
Thank you for your help on creating a raster file from polygons.
I am creating a big file using gdal_translate and I got the following message:
gdal_translate landcover.img -a_ullr -1170075 3217665 2324145 188865
-scale 0 255 0 0 -outsize 116474 100960 test.img
Input file size is 33146, 52402
0ERROR 6: A 116474 pixels x 100960 lines x 1 bands Byte image would be
larger than 4GB
but this is the largest size a TIFF can be.  Creation failed.
Is there any way I can create this raster (other formats) without this
space limitation?
Thanks,
Limei
