[gdal-dev] Some questions ...
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 15 17:23:28 EST 2008
mario beaulieu wrote:
> GDAL version 1.5
> I have 2 questions.
> 1) I want to add a raster band to a GEOTIFF dataset. Is there any
> method to do it since the driver seem not to support the AddBand method?
> ERROR 6: Dataset does not support the AddBand() method.
Mario,
The AddBand() method is the correct method, but hardly any drivers support
adding a band to an existing dataset. I suspect the MEM and VRT drivers
are the only ones that currently support it.
> 2) I want to create 1 BBP raster band and save it in TIFF. How can I do?
Pass the creation option NBITS=1 to the GTiff driver Create/CreateCopy
methods. Note, this may not work properly in pre-GDAL/OGR 1.5 versions.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
