[gdal-dev] Simple Extraction of GCPs from metadata and reprojection
mattia
mattia.parigiani at gmail.com
Tue Feb 19 14:53:34 EST 2008
This will probably sound simple to some of the folks, but its still a matter
of confusion for me..
I have a GTif file with the following metadata as from gdalinfo utility (in
a few a lines):
I would appreciate if anyone could help me in telling me how I can possibly
derive 4 GCPs using the
GRINGPOINTLATITUDE, GRINGPOINTLONGITUDE metadata fields or possibly the
metadata in:
EASTBOUNDINGCOORDINATE=134.930768655651
WESTBOUNDINGCOORDINATE=88.3307203917252
NORTHBOUNDINGCOORDINATE=64.7989342568829
SOUTHBOUNDINGCOORDINATE=20.7060304288409
I just dont get what kind of calculations / transformations are required to
be done in order to derive the GCPs for reprojection...
gdalinfo output:
Driver: GTiff/GeoTIFF
Files: out.tif
Size is 1354, 4630
Coordinate System is `'
Metadata:
RANGEBEGINNINGDATE=2007-01-04
RANGEBEGINNINGTIME=03:53:46.531545
RANGEENDINGDATE=2007-01-04
RANGEENDINGTIME=04:05:10.447733
DAYNIGHTFLAG=Day
GRINGPOINTLATITUDE.1=64.763542175293, 58.4916687011719, 20.8642158508301,
24.1079616546631
GRINGPOINTLONGITUDE.1=91.4718399047852, 134.930770874023, 110.696083068848,
88.3426055908203
AveragedBlackBodyTemperature=290.0179
AveragedMirrorTemperature=279.4261
AveragedFocalPlane1Temperature=270.9242
AveragedFocalPlane2Temperature=271.1122
AveragedFocalPlane3Temperature=83.35484
AveragedFocalPlane4Temperature=83.02042
QAPERCENTMISSINGDATA.1=0
QAPERCENTMISSINGDATA.2=0
QAPERCENTINTERPOLATEDDATA.1=0
QAPERCENTINTERPOLATEDDATA.2=0
QAPERCENTOUTOFBOUNDSDATA.1=40
QAPERCENTOUTOFBOUNDSDATA.2=0
PGE_Version=3.0.0
ASSOCIATEDPLATFORMSHORTNAME.1=Terra
Satellite=Terra
Number of Scans=463
Number of Day mode scans=463
Number of Night mode scans=0
Incomplete Scans=1
Max Earth View Frames=1354
Thanks in advance
Mattia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080219/221384ff/attachment.html
