[gdal-dev] gdal_merge and BIGTIFF option fails
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 22 10:55:44 EST 2008
WolfgangZ wrote:
> Hi,
> I'm trying to merge some tiles into a single tiff file that will be
> bigger than 4 GB. But when it reaches the 4GB the following error occurs:
> FIFFWriteEncodedTile() failed
> TIFFAppendToStrip: Maximum TIFF file size exeeded.
> I have also to report that in the very beginning I get following error:
> TIFFFetchStripThing: Sanity check on size of "TileOffsets" value failed.
> I'm using WFTools 2.0.4 on Ubuntu
Wolfgang,
I tried creating a bigtiff with gdal_translate and FWTools 2.0.6 and it
seemed to work. I suspect this was a temporarily problem fixed since
2.0.4. Could you try again with 2.0.6 and if the problem persists
file a ticket against GDAL with the details?
I did:
gdal_translate ~/utm.tif -outsize 100000 50000 big.tif
which with debug enabled reported:
GDAL: GDALOpen(/wrk/home/warmerda/utm.tif) succeeds as GTiff.
Input file size is 512, 512
0GTiff: Automatically flipping to Bigtiff due to large file size
GDAL: GDALOpen(big.tif) succeeds as GTiff.
GDAL: GDALDatasetCopyWholeRaster(): 100 line swath, bInterleave=0
...10...20...30...40...50...60...70...80...90...100 - done.
GDAL: GDALClose(big.tif)
GDAL: GDALClose()
GDAL: GDALClose(/wrk/home/warmerda/utm.tif)
GDAL: GDALDeregister_GTiff() called.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
