R: [gdal-dev] Expat support on MinGW/MSYS
marco.pasetti at alice.it
Tue Feb 26 11:33:52 EST 2008
Hi Ari,
sorry for the late (incredibly busy in these days);
I tried with your suggestion, but it doesn't work at all!
looking in config-status I found errors after line command
g++ [...] conftest.exe -I/lusr/local/include -L/usr/local/bin -lexpat conftest.cpp
dunno why!
I abandoned the will of adding expat support in gdal!
thanks anyway
Marco
Da: Ari Jolma [mailto:ari.jolma at tkk.fi]
Inviato: mer 20/02/2008 15.57
A: marco.pasetti at alice.it
Cc: gdal-dev at lists.osgeo.org
Oggetto: Re: [gdal-dev] Expat support on MinGW/MSYS
marco.pasetti at alice.it kirjoitti:
> Hi,
> I'm building GDAL 1.5.0 on Windows (XP SP2) using MSYS/MinGW environment;
> I built Expat 2.0.1, but I cannot configure GDAL with Expat support.
> I followed the BuildingWithMinGW Wiki (using pexports, libtool and
> perl commands), but it continues to find includes but not libraries!
Something's definitely not correct. I'm using the trunk version and I
get configure to find expat.h from c:\mingw\include and expat.dll.a
(which is created with pexports and libtool and the small perl utility)
from c:\mingw\lib with:
1) adding LIBS="$LIBS -lexpat" to configure (lines 23783 and 23787)
and
2) calling configure with
--with-expat=yes --with-expat-inc=/c/mingw/include
--with-expat-lib=-L/c/mingw/lib
Note the value for --with-expat-lib. It seems to be required although
the directory is known by the linker by default.
Regards,
Ari
> Someone could help me please?
> What happen if I disable Expat support?
> Thanks for support,
> Marco
> gdal-dev mailing list
Prof. Ari Jolma
Geoinformatiikka / Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080226/17d8a1a6/attachment.html
