[gdal-dev] nearblack: Warning 1: Band 1 is not of type GDT_Byte.
It can lead to unexpected results.
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 26 16:31:03 EST 2008
John Mitchell wrote:
> When I run the following command:
> nearblack -near 1 -nb 0 "c:\temp1\w3.tiftemp"
> I get the below warning
> Warning 1: Band 1 is not of type GDT_Byte. It can lead to unexpected
> results.
> The file now look very much different than the original source NITF,
> which I guess is what the "unexpected results" message meant.
> I have also attached the gdalinfo of converted nearblack file called
> 55439_gdalwarp_nearblack.gdalinfo
> When running gdalwarp to convert from NITF to geotiff is their a
> parameter that would output the file as a geotiff with the band as a
> type GDT_Byte, so that nearblack would correctly output the geotiff.
John,
Indeed, nearblack will just clamp all values larger than 255 to 255
and write out the result as GDT_Byte. So this could be quite badly
damaging your 16bit data.
You can add the following arguments to gdal_translate to convert to
byte data type using rescaling: "-scale -ot Byte".
This uses a default scaling algorithm. You might find it more appropriate
to control the scaling more carefully.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
