R: R: [gdal-dev] GDAL & Python
Christopher Barker
Chris.Barker at noaa.gov
Wed Feb 27 11:42:15 EST 2008
Marco Pasetti wrote:
> I'll try to reply as best as possible, it's very late here... And my poor
> english becames horrible when I'm tired ....
no problem -- it can wait until tomorrow!
> I should try again and write down the outputs.
that would be great.
> I rapidly read it; I should work on the problem, but I'm working on a larger
> project, and python enabling is just a part of it... And the former is again
> a little part of another bigger project I'm working on, that is my
> university thesis... I'm really sorry, I have no such time to spend on it...
no problem, we all do what we can.
> However I guess that the easiest way to enable python bindings in GDAL would
> be to build python itself with MinGW
I'm not so sure -- then you have to build all of Python, and who knows
what other extensions! The whole point of mingw is that is can build
stuff that works with regular old windows applications, and I have
successfully built python extensions with it, so it should be doable.
> I'm working on a building guide for both GRASS and QGIS as native windows
> binary. It's still a WIP, but if you want you can give it a glange:
> http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html
Thanks. I'm using a slightly older version of msys -- maybe I'll try
that upgrade, and see id that helps any.
> target is to obtain a GRASS+QGIS build as most complete as possible...
The python bindings to QGIS are getting a lot more use these days -- are
you building those?
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
