[Gdal-dev] Translation Error
Andrew de klerk
andrew.deklerk at gmail.com
Fri Feb 29 09:56:22 EST 2008
Hi all
I am attempting to import a shapefile into postgres using the following
command:
ogr2ogr -nlt POINT -f "PostgreSQL" -a_srs "EPSG:2054" PG:"dbname=xxxxx
user=xxxxx password=xxxxx host=localhost port=5432" grid1000.shp
When I run this I get the error:
ERROR 6: No translation for Transverse_Mercator_South_Orientated to PROJ.4
format is known
I would appreciate some assistance on getting round this error
Thanks
Andre
View this message in context: http://www.nabble.com/Translation-Error-tp15760215p15760215.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
