[gdal-dev] Source dataset during ogr2ogr
Christopher Condit condit at sdsc.edu
Fri Feb 29 16:14:07 EST 2008
I'm working on the KML 2.2 update for the KML OGR driver, and I'm
curious if there's some way to get access to the source dataset object
from the created dataset during an ogr2ogr call. In this case I'm
interested in looking at all the feature definitions from the source
dataset s.t. I can create the schema correctly in the KML output...
Thanks!
-Chris
