[gdal-dev] epsg_tr.py in reverse?
Moskovitz, Bob Bob.Moskovitz at conservation.ca.gov
Fri Feb 29 17:00:34 EST 2008
Hello All,
I would like to find a utility that would allow you to find the EPSG code given a proj4 string.  Sort of a epsg_tr.py in reverse.  Can a utility be written with the gdal api to do that?
Bob
Bob Moskovitz
Seismic Hazard Zonation Project
California Geological Survey
http://www.conservation.ca.gov/cgs/shzp<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080229/abed393d/attachment.html
