[gdal-dev] GDAL 1.5.0 questions
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 1 15:21:44 EST 2008
Roger Bivand wrote:
> Hi,
> Two questions: first on the size of GDAL 1.5.0 binaries - on both Linux
> (RHEL4
> i386) and Windows (MSYS/MinGW), the GDAL library libgdal.so.1.12.0 and
> respectively libgdal-1.dll are four times larger than those built on the
> same
> platforms with the same configure options (Linux 5019970 : 22203698;
> Windows
> 5279462 : 17919972). Have I missed a configure option or compile flag?
Roger,
Optimization and debugging selection changed significantly in 1.5.0. You
are likely getting build options "-O2 -g" instead of the old default of
"-O2", and so your library has debug info. Try:
export CXXFLAGS=-O2
./configure ...
> PS. The Gmane feed is still pointing at gdal-dev at lists.maptools.org.
I'm afraid that is beyond my control.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
