[gdal-dev] using GDAL to make a multi band image from several one-band images
Vincent Schut schut at sarvision.nl
Thu Jan 3 04:16:32 EST 2008
Yann Chemin wrote:
> Hello,
> I would like to use GDAL (in Python) for doing something like this.
...snip...
> The idea is to create a new file from an already existing one-band
> file, only thing is to have it multi-band.
> Maybe It is not the best way to start doing it...
Hello Yann,
no need to use gdal/python for this, you can do this with the
gdal_merge.py tool that comes with gdal. Use the -separate option, and
it will merge your single-band input files into a multiband output file.
See http://gdal.org/gdal_merge.html for more info.
Regards,
Vincent.
> Could anybody help please?
> thanks
> Yann
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
