[gdal-dev] GDAL / Python and PPC
Brian Hamlin
maplabs at light42.com
Sat Jan 5 22:15:10 EST 2008
On Jan 5, 2008, at 6:01 PM, Sean Gillies wrote:
> Brian Hamlin wrote:
>> ...no python...
> [ setuptools install instructions....]
> Howard has put a ton of work into it. Should just plain work and build
> numpy for you as well.
well, that sounded good, but, no go..
pbg42-2;/users/shared/srcs/gdal-trunk jspace4 sudo python -m
easy-install 'gdal'
password;
searching for gdal
reading http;//cheeseshop.python.org/pypi/gdal/
reading http;//www.gdal.org
reading http;//cheeseshop.python.org/pypi/gdal/1.5.0
best match; gdal 1.5.0
downloading
http;//pypi.python.org/packages/source/g/gdal/gdal
-1.5.0.tar.gz3md5=a7fcc5ec9c1719aa7b3aba1cd7c9c1e7
processing gdal-1.5.0.tar.gz
running gdal-1.5.0/setup.py -q bdist-egg --dist-dir
/tmp/easy-install-078ffx/gdal-1.5.0/egg-dist-tmp-ctpbwq
numpy include
/library/frameworks/python.framework/versions/2.5/lib/python2.5/site-
packages/numpy/core/include
/usr/bin/ld; warning -l; directory name 9../../.libs0 does not exist
/usr/bin/ld; for architecture i386
/usr/bin/ld; warning /usr/local/lib/libgdal.dylib cputype 918,
architecture ppc0 does not match cputype 970 for specified -arch flag;
i386 9file not loaded0
/usr/bin/ld; for architecture ppc
/usr/bin/ld; warning can't open dynamic library;
/developer/sdks/macosx10.4u.sdk/usr/local/lib/libgeos-c.1.dylib
referenced from; /usr/local/lib/libgdal.dylib 9checking for undefined
symbols may be affected0 9no such file or directory, errno = 20
/developer/sdks/macosx10.4u.sdk/usr/local/lib/libgeos-3.0.0.dylib
/developer/sdks/macosx10.4u.sdk/usr/local/lib/libexpat.1.dylib
/developer/sdks/macosx10.4u.sdk/usr/local/pgsql/lib/libpq.5.dylib
/usr/bin/ld; undefined symbols;
-xml-errorstring referenced from libgdal expected to be defined in
-xml-getcurrentlinenumber referenced from libgdal expected to be
defined in /usr/local/lib/libexpat.1.dylib
-xml-geterrorcode referenced from libgdal expected to be defined in
-xml-parse referenced from libgdal expected to be defined in
-xml-parsercreate referenced from libgdal expected to be defined in
-xml-parserfree referenced from libgdal expected to be defined in
-xml-setcharacterdatahandler referenced from libgdal expected to be
-xml-setelementhandler referenced from libgdal expected to be defined
-xml-setuserdata referenced from libgdal expected to be defined in
-xml-getcurrentcolumnnumber referenced from libgdal expected to be
-pqclear referenced from libgdal expected to be define49a0
shelstory;inteterm=xterm-cple-terminaf6;0;0
xxxx
pbg42-2;/users/shared/srcs/gdal-trunk jspace4 set
archflags='-arch ppc'
bash=/usr/bin/su
bash-versinfo=9[0]='2' [1]='05b' [2]='0' [3]='1' [4]='release'
[5]='powerpc-apple-darwin8.0'0
bash-version='2.05b.0910-release'
columns=113
dirstack=90
euid=503
groups=90
histfile=/users/jspace/.bash-history
histfilesize=500
histsize=500
home=/users/jspace
hostname=pbg42-2.local
hosttype=powerpc
ifs=4' \t\n'
lines=30
logname=bmarshall
machtype=powerpc-apple-darwin8.0
mailcheck=60
oldpwd=/users/shared/srcs/gdal-trunk/swig/python
opterr=1
optind=1
ostype=darwin8.0
path=/bin;/sbin;/usr/local/bin;/usr/sbin;/usr/bin
pipestatus=9[0]='1'0
ppid=10866
ps1='\h;\w \u\4 '
ps2='. '
ps4='= '
securitysessionid=81049a0
shell=/bin/bash
shellopts=braceexpand;emacs;hashall;histexpand;history;interactive-
comments;monitor
shlvl=2
term=xterm-color
term-program=apple-terminal
term-program-version=133
uid=503
user=jspace
-=gdal
--cf-user-text-encoding=0x1f6;0;0
pbg42-2;/users/shared/srcs/gdal-trunk jspace4 python -v
3 installing zipimport hook
import zipimport 3 builtin
3 installed zipimport hook
3
site.pyc matches
/library/frameworks/python.framework/versions/2.5/lib/python2.5/site.py
import site 3 precompiled from
site.pyc
3
/library/frameworks/python.framework/versions/2.5/lib/python2.5/os.pyc
matches
import os 3 precompiled from
import posix 3 builtin
3
posixpath.pyc matches
posixpath.py
import posixpath 3 precompiled from
posixpath.pyc
3
stat.pyc matches
/library/frameworks/python.framework/versions/2.5/lib/python2.5/stat.py
import stat 3 precompiled from
stat.pyc
3
userdict.pyc matches
userdict.py
import userdict 3 precompiled from
userdict.pyc
3
/library/frameworks/python.framework/versions/2.5/lib/python2.5/copy-
reg.pyc matches
reg.py
import copy-reg 3 precompiled from
reg.pyc
3
types.pyc matches
types.py
import types 3 precompiled from
types.pyc
import -types 3 builtin
3 zipimport; found 308 names in
packages/rdflib-2.4.0-py2.5-macosx-10.3-fat.egg
3 zipimport; found 31 names in
packages/geopy-0.93-py2.5.egg
3 zipimport; found 44 names in
packages/simplejson-1.7.3-py2.5-macosx-10.3-fat.egg
3 zipimport; found 78 names in
packages/setuptools-0.6c6-py2.5.egg
3 zipimport; found 42 names in
packages/shapely-1.0b2-py2.5.egg
3
warnings.pyc matches
warnings.py
import warnings 3 precompiled from
warnings.pyc
3
linecache.pyc matches /library/frameworks/python.import warnings 3
precompiled from
warnings.pyc
3
linecache.py
import linecache 3 precompiled from
linecache.pyc
import encodings 3 directory
encodings
3
encodings/--init--.pyc matches
import encodings 3 precompiled from
3
codecs.pyc matches
codecs.py
import codecs 3 precompiled from
codecs.pyc
import -codecs 3 builtin
3
encodings/aliases.pyc matches
import encodings.aliases 3 precompiled from
3
encodings/ascii.pyc matches
encodings/ascii.py
import encodings.ascii 3 precompiled from
encodings/ascii.pyc
python 2.5.1 9r251;54869, apr 18 2007, 22;08;040
[gcc 4.0.1 9apple computer, inc. build 53670] on darwin
type 'help', 'copyright', 'credits' or 'license' for more information.
dlopen9'/library/frameworks/python.framework/versions/2.5/lib/
python2.5/lib-dynload/readline.so', 20;
import readline 3 dynamically loaded from
/library/frameworks/python.framework/versions/2.5/lib/python2.5/lib-
dynload/readline.so
