[gdal-dev] Shapefile to Lambert Azimuthal Equal Area
Kent Eschenberg
eschenbe at psc.edu
Mon Jan 7 11:29:17 EST 2008
Any idea why I cannot convert a shapefile to the Lambert azimuthal equal area
projection? I tried
ogr2ogr -t_srs EPSG:9820 -f "ESRI Shapefile" destination.shp source.shp
and saw the message
ERROR 6:
EPSG PCS/GCS code 9820 not found in EPSG support files. Is this a valid
EPSG coordinate system?
Failed to process SRS definition: EPSG:9820
I'm using GDAL 1.4.2 on Fedora core 6.
TIA!
Kent
Pittsburgh Supercomputing Center
