[gdal-dev] RFC-19 revised
Even Rouault
even.rouault at mines-paris.org
Mon Jan 7 16:49:20 EST 2008
Hi all,
After more feedback coming from discussions on IRC, I've decided to revise the
terms of http://trac.osgeo.org/gdal/wiki/rfc19_safememalloc.
The summary of changes is that I would only add 2 new functions - VSIMalloc2
and VSIMalloc3 - which would have the same behaviour of the previously named
CPLSafeMalloc2 and CPLSafeMalloc3. Their behaviour would be consistent with
the behaviour of current VSIMalloc. (The 'safe' qualifier could have implied
that other memory allocation functions are not safe to use, which is not the
case).
The proposed functions for detecting overflows when doing arithmetic
operations (CPLSafeMul/CPLSafeSizetCastToInt), and the way of implementing
them (templates vs not templates), don't make enough consensus and are
retracted. There could be indeed a more general need for "safe" arithmetic,
and not just restrict them to multiplication of size_t variables. The subject
of security is far from being fully covered... ;-)
So, I call for a new vote on the updated RFC.
Best regards,
Even
