[gdal-dev] join CSV to shapefile, column width question
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 8 14:31:46 EST 2008
keith lewis wrote:
> Hello,
> I'm joining tabular data (csv) to a shapefile. The new String fields are
> always 80 char wide. I tried to define the column width by creating a
> .CSVT file in this manner.
> "String (100)",String (100)"
> However, this has no effect on the new columns that are joined to the
> shapefile. The Shapefile specification allows String fields up to 255
> char. How can I create String fields greater than 80 char? Thanks
Keith,
I would suggest you submit a bug report demonstrating the problem with setting
shapefile(dbf) field widths based on a .csvt file and I can look into it.
The approach seems reasonable.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
