[gdal-dev] using gdal_translate with -dsco switch
Dane Springmeyer
blake at hailmail.net
Wed Jan 9 18:04:06 EST 2008
do gdal utilities that convert to vector formats use the same drivers
as ogr?
-dane
On Jan 9, 2008, at 2:05 PM, Brian Hamlin wrote:
> I think altitudeMode is for ogr2ogr using the KML driver.. thats
> where I have used it
> -Brian
> On Jan 9, 2008, at 1:33 PM, Dane Springmeyer wrote:
>> I am converting elevation data in Gtiff format to contours in KML
>> format, but running into a usage problem when attempting to create
>> 3D contours.
>> I noted the discussion here about enabling correct 3D
>> representation in Google Earth (This is a great addition):
>> http://trac.osgeo.org/gdal/ticket/1570
>> and the need to use driver specific name=value option for ogr2ogr
>> of "-dsco AltitudeMode=absolute" here:
>> http://www.gdal.org/ogr/drv_kml.html
>> When I attempt to use it with gdal_translate the utility simply
>> returns the usage instructions. I'm guessing that either I am
>> putting the flag in the wrong place or this option is not enabled
>> in gdal_contour, even though I am able to successfully write KML
>> with gdal_contour.
>> I'm running GDAL 1.5.0b2 on mac os x. This works for me:
>> gdal_contour -f KML -i 5.0 blakely.tif
>> five_meter_contours.kml //Note: the -3d switch is
>> left out intentionally since it does not seem to affect KML output
>> These do not:
>> gdal_contour -f KML -i 5.0 blakely.tif five_meter_contours.kml -
>> gdal_contour -f KML -dsco AltitudeMode=absolute -i 5.0 blakely.tif
>> Anyone have ideas of the problem?
>> Regards,
>> Dane
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
