Ahmet,
The best way to handle this is to compile gdal without geos and then link geos into your code and use it only when you want to. You will have to write a function to swap the geometries back and forth between ogr and geos but it is minimal becaue Frank has already written them and you can reuse most of them even when geos is not linked in.
Best regards,
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Fri, 11 Jan 2008 16:06:59
To:Ahmet Murat Özdemiray <ahmeto at cs.bilkent.edu.tr>
Cc:gdal-dev <gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] Re: OGR/ GEOS GetNextFeature problem
Ahmet Murat Özdemiray wrote:
> Hi,
> I have a problem with OGRLayer.GetNextFeature() method. I did not
> where to post this, so here I am.
Murat,
This would be a good topic to discuss on the gdal-dev mailing
list. I am taking the liberty of cc:ing my reply there since the
issue does not seem to be confidential in any way.
> I had a working display program using gdal, which reads ESRI shape
> files and displays contents of it on a Windows Form. I downloaded gdal
> version 1.4.3 and compiled on Win32 using nmake. It was working fine,
> until I realized that, geometric operations like Contains, Disjoints,
> Intersects etc. does not work without GEOS library. So I downloaded
> lastest versions of gdal (1.5.0) and geos(3.0.0), compiled both of
> them with release configuration for Win32 with VS2005.
> When I updated my old program, I realized that things are displayed
> slower. Started debugging and saw that GetNextFeature takes up to 15
> secs for some features and a shape file containing all countries of
> the world takes 2 minutes to display. Then, I downloaded FWTools
> 2.0.4, changed all bindings to FWTools' libraries and I got similar
> results. However, when I try to open same file with OpenEV, it can
> display it in 2 secs.
> Here's are a few lines of my code, what do I do wrong?
> layer->SetSpatialFilterRect(-180, -90, 180, 90);
> layer->ResetFeature();
I assume the above is actually layer->ResetReading()?
> OGRFeature* ftr;
> while((ftr = layer->GetNextFeature()) != NULL)
> // do something
> OGRFeature::DestroyFeature( ftr );
You haven't done anything wrong, but you have learned that GEOS
intersection tests can be inordinately expensive.
Hmm, on further reflection reading from a shapefile using a rectangular
filter such as any filter set with SetSpatialFilterRect() should short
circuit use of GEOS as per the code in OGRLayer::FilterGeometry():
/* Fallback to full intersect test (using GEOS) if we still */
/* don't know for sure. */
if( m_bFilterIsEnvelope )
return TRUE;
else
if( OGRGeometryFactory::haveGEOS() )
return m_poFilterGeom->Intersects( poGeometry );
else
return TRUE;
I have skimmed the Shapefile driver and not noticed anything that should
defeat this logic but I might be missing something. If you can demonstrate
the issue in some fashion I can easily reproduce, I'd like to dig into it.
Perhaps using:
ogrinfo -ro -spat -180 -90 180 90 ..
on your shapefile. If you can do that, and can make the shapefile available
to me to reproduce the problem with I should be good to go. You should
also file a Trac ticket at that point though you don't need to attach
the dataset if it is large or private.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
