[Gdal-dev] SDE to PostgreSQL/PostGIS
Pål Kristensen
pal.kristensen at statkart.no
Thu Jan 17 03:28:57 EST 2008
Hi!
Thanks for the help! Unfortunately there seems to be something wrong. I got
the attached error message when executing the following command:
SET PG_USE_COPY=YES
ogr2ogr -nlt LINESTRING -nln n50_bilveg -lco GEOMETRY_NAME=the_geom -a_srs
EPSG:32633 -f PostgreSQL PG:"dbname=kartdata user=xxx host=xx.xx.xx.xx"
SDE:xx.xx.xx.xx,5157,,n50,n50,n50.bilveg
http://www.nabble.com/file/p14914348/ogr2ogr_error.png
Do you know what is causing this?
Ogrinfo --formats however shows both SDE and PostgreSQL support.
Regards
Pål Kristensen
Howard Butler-3 wrote:
> I have placed a PostGIS plugin on the download page. Please confirm
> that it works for you...
> http://download.osgeo.org/gdal/win32/1.5/
> Howard
> On Jan 16, 2008, at 2:12 AM, Pål Kristensen wrote:
>> Hi!
>> I'm trying to convert some data (approx 10GB) from SDE to PostgreSQL/
>> PostGIS
>> using ogr2ogr. Due to the large amount of data it's not practical to
>> use
>> shapefiles as intermediate storage. The problem is that I can't find
>> any
>> GDAL/OGR windows binaries with both SDE support and PostgreSQL
>> support.
>> The windows binaries which you can download form
>> http://download.osgeo.org/gdal/win32/1.5/ does support SDE 9.x, by
>> using the
>> plugins available at the same link. However these win binaries does,
>> for
>> some reason, not support PostgreSQL.
>> I then tried to use the latest FWtools (2.0.4) that has PostgreSQL
>> support,
>> but I cant find any SDE plugins that works with newer FWtools than
>> version
>> 1.3.9.
>> So basically FWtools works with PostgreSQL and the win32 binaries
>> from the
>> GDAL web site works with SDE.
>> Is there any win32 compilation of the latest gdal 1.5.0 that has both
>> PostgreSQL and SDE 9.x support??
>> Regards,
>> Pål Kristensen
>> View this message in context:
>> http://www.nabble.com/SDE-to-PostgreSQL-PostGIS-tp14873585p14873585.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/SDE-to-PostgreSQL-PostGIS-tp14873585p14914348.html
