[Gdal-dev] SDE to PostgreSQL/PostGIS
Pål Kristensen pal.kristensen at statkart.no
Thu Jan 17 10:41:41 EST 2008
Thanks!!
Works like a charm.
Regards
Pål
Howard Butler-3 wrote:
> Oops.  Can you try the new version that is available from the download
> site?
> Howard
> On Jan 17, 2008, at 3:34 AM, Martin Chapman wrote:
>> Correct.
>> Martin Chapman
>> Chief Software Architect
>> Fortified Datacom Inc.
>> http://www.fortifieddatacom.com
>> mchapman at fortifieddatacom.com
>> 303-324-1065
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.osgeo.org
>> [mailto:gdal-dev-bounces at lists.osgeo.org
>> ] On Behalf Of Pål Kristensen
>> Sent: Thursday, January 17, 2008 2:06 AM
>> To: gdal-dev at lists.osgeo.org
>> Subject: RE: [Gdal-dev] SDE to PostgreSQL/PostGIS
>> Hi!
>> Thanks! I assumed that it was something like that. The SDE plugin
>> seems to
>> work correctly, but the problem is the PostgreSQL plugin that Howard
>> Butler
>> compiled for me yesterday.
>> So, the solution would be to recompile the PostgreSQL plugin without
>> debug
>> support?
>> Regards,
>> Pål Kristensen
>> mchapman wrote:
>>> Whoops, from the image looks like your application or the plugin is
>>> compiled with the debug version and it doesn't like the different
>>> heap
>>> space.
>>> Martin Chapman
>>> 303-324-1065
>>> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Pål Kristensen
>>> Sent: Thursday, January 17, 2008 1:29 AM
>>> Subject: Re: [Gdal-dev] SDE to PostgreSQL/PostGIS
>>> Hi!
>>> Thanks for the help! Unfortunately there seems to be something
>>> wrong. I
>>> got
>>> the attached error message when executing the following command:
>>> SET PG_USE_COPY=YES
>>> ogr2ogr -nlt LINESTRING -nln n50_bilveg -lco GEOMETRY_NAME=the_geom
>>> -a_srs
>>> EPSG:32633 -f PostgreSQL PG:"dbname=kartdata user=xxx
>>> host=xx.xx.xx.xx"
>>> SDE:xx.xx.xx.xx,5157,,n50,n50,n50.bilveg
>>> http://www.nabble.com/file/p14914348/ogr2ogr_error.png
>>> Do you know what is causing this?
>>> Ogrinfo --formats however shows both SDE and PostgreSQL support.
>>> Regards
>>> Pål Kristensen
>>>> I have placed a PostGIS plugin on the download page.  Please confirm
>>>> that it works for you...
>>>> http://download.osgeo.org/gdal/win32/1.5/
>>>> Howard
>>>> On Jan 16, 2008, at 2:12 AM, Pål Kristensen wrote:
>>>>> Hi!
>>>>> I'm trying to convert some data (approx 10GB) from SDE to
>>>>> PostgreSQL/
>>>>> PostGIS
>>>>> using ogr2ogr. Due to the large amount of data it's not practical
>>>>> to
>>>>> use
>>>>> shapefiles as intermediate storage. The problem is that I can't
>>>>> find
>>>>> any
>>>>> GDAL/OGR windows binaries with both SDE support and PostgreSQL
>>>>> support.
>>>>> The windows binaries which you can download form
>>>>> http://download.osgeo.org/gdal/win32/1.5/ does support SDE 9.x, by
>>>>> using the
>>>>> plugins available at the same link. However these win binaries
>>>>> does,
>>>>> for
>>>>> some reason, not support PostgreSQL.
>>>>> I then tried to use the latest FWtools (2.0.4) that has PostgreSQL
>>>>> support,
>>>>> but I cant find any SDE plugins that works with newer FWtools than
>>>>> version
>>>>> 1.3.9.
>>>>> So basically FWtools works with PostgreSQL and the win32 binaries
>>>>> from the
>>>>> GDAL web site works with SDE.
>>>>> Is there any win32 compilation of the latest gdal 1.5.0 that has
>>>>> both
>>>>> PostgreSQL and SDE 9.x support??
>>>>> Regards,
>>>>> Pål Kristensen
>>>>> View this message in context:
>>>>> http://www.nabble.com/SDE-to-PostgreSQL-PostGIS-tp14873585p14873585.html
>>>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> http://www.nabble.com/SDE-to-PostgreSQL-PostGIS-tp14873585p14914348.html
>> http://www.nabble.com/SDE-to-PostgreSQL-PostGIS-tp14873585p14914870.html
View this message in context: http://www.nabble.com/SDE-to-PostgreSQL-PostGIS-tp14873585p14921866.html
