[gdal-dev] adding the pds format ISIS
cartrite
stpoppy at ptd.net
Fri Jan 18 19:08:07 EST 2008
This is really a reply to your next message which never got to my email
account.
I did go though with a make install and everything worked on my end. I
thought that the object files would be needed in the pds folder after
building but apparently this isn't so. Sorry about that.
I left Ross a note to fill out a ticket if he wants to fix this. I don't
have the file he is trying to open. I can open .cub files on my end.
Steve
On Fri, 2008-01-18 at 15:58 -0500, Frank Warmerdam wrote:
> cartrite wrote:
> > Hi,
> > I was wondering how one would add a PDS, ISIS3 reader. I didn't see an
> > option in configure help. There is a folder under formats. And I can run
> > make from the pds folder, but I'm not sure how to link.
> Steve,
> In GDAL 1.5.0 the PDS, ISIS2, and ISIS3 drivers should be built into GDAL
> by default. They do not depend on external libraries so no configure
> options are required.
> You can confirm availability of a driver using the --format switch.
> eg.
> warmerda at gdal64[27]% gdalinfo --format isis3
> Format Details:
> Short Name: ISIS3
> Long Name: USGS Astrogeology ISIS cube (Version 3)
> Help Topic: frmt_various.html#ISIS3
> Best regards,
