[gdal-dev] gdal_merge vs gdalwarp for mosaicking
John Mitchell
mitchelljj98 at gmail.com
Mon Jan 21 06:11:51 EST 2008
If I need to be able to mosaic tiles together but do not need to change the
projection, then I can run gdal_merge which will run faster than gdalwarp.
My question is their any advantage to running gdalwarp as far as:
1.) data quality
2.) scalability: I will be mosaicking many gigabytes (5GB-100GB) worth of
tiles together will gdal_merge be able to handle this?
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080121/f5d5e379/attachment.html
