[gdal-dev] gdal_merge vs gdal_translate for reducing resolution
Adam Nowacki
nowak at xpam.de
Mon Jan 21 07:57:22 EST 2008
> I have tried running both gdal_merge and gdal_translate for reducing the
> resolution of individual tiles and I have found that both the data
> quality and speed for the conversion are identical. Since everything is
> identical is their any reason to prefer one program over the other for
> reducing resolution?
Both do equally bad at reducing resolution since both use nearest
neighbor sampling. gdalwarp with bilinear resampler might do better but
I would suggest using gdaladdo with average filter instead.
