[gdal-dev] Compiling gdal-svn-stable-2008.01.21 with libcurl
support
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 21 20:41:54 EST 2008
Miguel Fernandes wrote:
> Hello,
> I'm compiling gdal version gdal-svn-stable-2008.01.21 with libcurl
> libcurl-7.15.1-msvc-win32-ssl-0.9.8a-zlib-1.2.3 support and netcdf 3.6.1
> using MC VC7.
> I'm having a linkage error in function select in file gdalhttp.cpp, i've
> tried to look for the declaration of this function in the code but i'm
> not being able to find it, is it part of gdal code or i'm i missing some
> library, i've checked the includes and i seem to have them all. The
> output is the following:
> link /nologo /dll /debug /INCLUDE:_OGRFeatureStylePuller
> /INCLUDE:_OSRValidate /INCLUDE:_OPTGetProjectionMethods
> /INCLUDE:_OGR_G_GetPointCount /INCLUDE:_OGRRegisterAll
> /INCLUDE:_GDALSimpleImageWarp at 36 /INCLUDE:_GDALReprojectImage at 48
> /INCLUDE:_GDALComputeMedianCutPCT at 32 /INCLUDE:_GDALDitherRGB2PCT at 28 /IN
> CLUDE:_OCTNewCoordinateTransformation at 8 /INCLUDE:_vbSafeArrayToPtr at 16
> port\*.obj gcore\*.obj alg\*.obj frmts\o\*.obj
> ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib
> vb6\vb6_support.obj odbc32.lib odbccp32.lib user32.lib
> C:\Programas\netCDF_3.6.1\lib\netcdf.lib
> C:\Programas\libs\libcurl\libcurl_imp.lib gcore\Version.res
> /out:gdal15.dll /implib:gdal_i.lib
> Creating library gdal_i.lib and object gdal_i.exp
> gdalhttp.obj : error LNK2019: unresolved external symbol
> __imp__select at 20 referenced in function "enum CPLErr __cdecl
> CPLHTTPFetchMulti(struct CPLHTTPRequest *,
> int,char const * const *)"
> (?CPLHTTPFetchMulti@@YA?AW4CPLErr@@PAUCPLHTTPRequest@
> @HPBQBD at Z)
> gdal15.dll : fatal error LNK1120: 1 unresolved externals
> Can anyone point where i can find the declaration of this function or
> why the linker isn't finding it.
Miguel,
Try adding wsock32.lib in your CURL_LIB declaration in nmake.opt. Frankly
I'm quite surprised that gdalhttp.cpp uses select() directly.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
