[gdal-dev] Conversion problem proj4 -> wkt ->proj4
Oliver Eichler
oliver.eichler at gmx.de
Tue Jan 29 02:54:05 EST 2008
Ok, solved it. Found a hint by chance :)
You have to add +wktext
+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs
Oliver
-------- Original-Nachricht --------
> Datum: Tue, 29 Jan 2008 08:09:16 +0100
> Von: "Oliver Eichler" <oliver.eichler at gmx.de>
> An: gdal-dev at lists.osgeo.org
> Betreff: [gdal-dev] Conversion problem proj4 -> wkt ->proj4
> Hi,
> I try to convert a proj4 string into wkt to store it into a GeoTiff. Later
> on
> I need to restore the projection from the string. However the most
> important
> part "+nadgrids=@null" is missing. See attached file. Anyone knows how to
> "do
> it right"?
> Thanks
> Oliver
