[gdal-dev] gdalwarp and the geos projection
Bas Retsios
retsios at itc.nl
Tue Jan 29 08:17:18 EST 2008
Hi!
We use the geos projection in gdalwarp, but only as a source (not as a
target).
The images we receive in geos projection are from the meteorological
satellites Meteosat-8 and Meteosat-9 (MSG).
And the size of most bands is 3712x3712 pixels.
I noticed your 3700x3700 images, therefore I got curious: are you trying
to convert back to the projection of the MSG images?
Anyway, the only suspicious part I noticed in your gdalwarp command is
the +h=745331460 parameter.
+h is the satellite height, in meters. This "height" is the distance
from the ellipsoid (thus not from the centre of the earth). For MSG
(which is a geostationary satellite), the correct value is +h=35785831.
Your value is about 20 times higher, which is two times the earth-moon
distance. Are you sure you have an image taken from that far away?
See also:
http://www.remotesensing.org/geotiff/proj_list/geos.html
Cheers,
Bas.
Ir. V. (Bas) Retsios
Software Developer
Geo-information Processing Department
International Institute for Geo-information Science and Earth Observation (ITC)
P.O. Box 6, 7500 AA Enschede, The Netherlands
Phone +31 (0)53 4874 573, telefax +31 (0)53 4874 335
E-mail retsios at itc.nl, Internet http://www.itc.nl
Andrew Chamberlain wrote:
> Hi All,
> Just wondering if anyone can help. Apologies if this is the wrong
> mailing list, but I couldn't find any other for GDAL users.
> I'm using gdalwarp to project an image from Plate Carree (proj=eqc) to
> Geostationary Satellite projection (proj=geos), and I'm finding that
> the east and west edges of the resulting Earth-disk are being cut off
> (at the sides of the containing image). I would estimate the clipping
> to be ~100 pixels on each side (the overall width is 3700).
> The source image has the projection details given below, and the
> command I'm using is:
> gdalwarp -t_srs '+proj=geos +lon_0=0.0 +h=745331460 +x_0=0.0
> +y_0=0.0' -ts 3700 3700 source_eqc.tif dest_geos.tif
> Has anyone seen this problem before with the geos projection? When I
> try with the ortho projection, the full Earth disk is rendered.
> Andy
> Size is 16384, 8192
> Coordinate System is:
> PROJCS["unnamed",
> GEOGCS["unnamed",
> DATUM["unknown",
> SPHEROID["unretrievable - using
> WGS84",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Equirectangular"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",0],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]]]
> Origin = (-20036285.350299999117851,10018754.171399999409914)
> Pixel Size = (2445.835614050000004,-2445.835614050000004)
> Metadata:
> AREA_OR_POINT=Area
> Corner Coordinates:
> Upper Left (-20036285.350,10018754.171) ( 0d 0'0.01"E, 90d 0'0.00"N)
> Lower Left (-20036285.350,-10017531.179) (179d59'20.45"W, 89d59'20.71"S)
> Upper Right (20036285.350,10018754.171) ( 0d 0'0.01"E, 90d 0'0.00"N)
> Lower Right (20036285.350,-10017531.179) (179d59'20.45"E, 89d59'20.71"S)
> Center ( -0.000, 611.496) ( 0d 0'0.00"W, 0d 0'19.91"N)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
