[gdal-dev] Lat/long & distance/heading calculation
Meek, Allan (Contractor) Allan.Meek at drdc-rddc.gc.ca
Tue Jan 29 10:22:22 EST 2008
Thanks to everybody for the replies. I had actually found the formula
for distance between
two lat-lon coordinates on this page. If only I'd scrolled down a little
bit, I'd have found this
formula!
Allan
Sent: January 28, 2008 8:46 PM
To: Ray Gardener
Cc: Meek, Allan (Contractor); gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Lat/long & distance/heading calculation
This might be what you're looking for :
http://www.movable-type.co.uk/scripts/latlong.html
Look for the section : Destination point given distance and bearing from
start point
-Lennox
On Jan 28, 2008 7:55 PM, Ray Gardener <rayg at daylongraphics.com> wrote:
If you can use UTM or similar coords, then
x = cos(heading) * distance + start_pos_x
y = sin(heading) * distance + start_pos_y
Assuming heading in clockwise radians with north = up.
Then you can inverse transform (x, y) from UTM to lat/lon.
Ray
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080129/b913e033/attachment-0001.html
