[gdal-dev] GDAL Java bindings, compiled for Windows
Stefan Keller
sfkeller at gmail.com
Wed Jan 30 15:57:13 EST 2008
Hi all,
There have been at least two threads in the last weeks about GDAL-Java
binding. And I assume that several people interested in Java are listening
on this mailing lists.
Question to the GDAL maintainers (Frank, Mateusz?): What about to use the
Wiki like http://trac.osgeo.org/gdal/wiki/GdalOgrInJava to share
experiences?
Stefan
2008/1/30, Daniele Romagnoli <dany.geotools at gmail.com>:
> Hello Armin,
> I dont know if a version of GDAL containing ready to use Java bindings
> (DLL) exists.
> I guess you should compile them by yourself using SWIG (proper makefile to
> build Java bindings are already contained in GDAL).
> Anyway, I'm working on a project which deeply leverages on JAVA bindings
> for GDAL 1.4.4.
> The project is available here: https://imageio-ext.dev.java.net/
> The homepage contains a link to a setup guide which illustrates,
> step-by-step, how to setup all the required elements (Hence, the GDAL Java
> bindings generation too).
> You can take a look on that document. (LINK:
> https://imageio-ext.dev.java.net/svn/imageio-ext/trunk/documentation/ImageioExt-SetupGuide.pdf
> It is actually on SVN: when asked for identification, you can set "guest"
> as user with no password.
> If you are not interested in some topics (such as kakadu, ecw, mrsid) you
> can just skip those sections as well as the patch topic.
> Note that it is not a definitive guide so it may be slightly changed in
> the future (since I'm working on some maven procedures tunings).
> You will notice that building GDAL and JAVA bindings is not a really hard
> task.
> However, if you encounter some problems, I can build a basic GDAL (without
> external libraries) as well as Java bindings for you.
> I can start the building in background.
> Let me know.
> Best Regards,
> Daniele
> On Jan 29, 2008 10:51 PM, Armin Burger <armin.burger at gmx.net> wrote:
> > Hello everybody
> > does anybody know if there is somewhere a compiled version (for Windows)
> > of GDAL including Java bindings available that could be used for
> > extracting basic information from various types of image formats
> > (extent, projection, bands, etc)? An older version like 1.3 would be
> > fully sufficient.
> > Before just calling the gdalinfo executable and parsing the output with
> > Java I would like to be sure there are no other alternatives currently
> > available.
> > Thanks for any help
> > Armin
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Eng. Daniele Romagnoli
> Software Engineer
> GeoSolutions S.A.S.
> Via Carignoni 51
> 55041 Camaiore (LU)
> Italy
> phone: +39 0584983027
> fax: +39 0584983027
> mob: +39 328 0559267
> http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080130/ba7ccf09/attachment.html
