[gdal-dev] Select a geometry attribute from multiple geometry
input?
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 30 15:57:40 EST 2008
Stefan Keller wrote:
> Frank,
> I can imagine that adding multiple geometries to OGR would touch some
> core components.
> > The OGR data model assumes at most one geometry per feature.
> I assumed that. My proposal rather would be, that users have at least a
> choice which geometry the input driver takes. This would restrict the
> solution to the input drivers (GML, Interlis 1, Interlis 2, others?). I
> would simply add a (common) format specific option (e.g. -dsco
> GeometryField=fieldname). What do you think?
Stefan,
-dsco (DataSource Creation Option) applies only when creating a datasource,
not when opening an existing datasource for read access.
In theory it could be supported via an environment/config variable, or
perhaps encoded into the datasource name in some funky way.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
