[gdal-dev] Strong Naming of C# Wrappers
Tamas Szekeres szekerest at gmail.com
Thu Jan 31 15:03:59 EST 2008
Jason,
Please file a ticket for this issue, I'll take care of this.
The /keyfile compiler option is quite VS2005 specific, however I think
we have alternative options to achieve the same results which is
compiler neutral.
Best regards,
Tamas
2008/1/31, Jason Beverage <jasonbeverage at gmail.com>:
> Hi all,
> I've been using the C# wrappers that come with FWTools, and I noticed that
> they are not strongly named.  This is causing a problem for my project as we
> require everything to be strongly named.
> I noticed that the makefile.vc has a "sign" step that generates the gdal.snk
> file, but it is not used after that.
> If you change the gdal_csharp target to include the /keyfile argument, it
> should produce strongly named assemblies:
> $(CSC) /debug:full /keyfile:gdal.snk /target:library /out:ogr_csharp.dll
> ogr\*.cs
> $(CSC) /debug:full /keyfile:gdal.snk /target:library /out:gdal_csharp.dll
> gdal\*.cs
> /out:gdalconst_csharp.dll const\*.cs
> $(CSC) /debug:full /keyfile:gdal.snk /target:library /out:osr_csharp.dll
> osr\*.cs
> It would be great if the bindings that come from the FWTools distro become
> the "official" way to download the binaries and they are signed when we get
> them.
> Thanks!
> Jason
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
