[gdal-dev] The proj.dll mistery
Andrew Brooks
arb at sat.dundee.ac.uk
Tue Jul 1 05:48:20 EDT 2008
On Tue, 01 Jul 2008 00:55:28 +0100, Martin Chapman <mchapman at texelinc.com> wrote:
> I apologize that VantagePoint caused a problem for you. We will make the
> fix to the install and get the proj.dll out of the system32 directory.
There's nothing wrong with installing a shared library into a shared
directory. But it's unforgivable to replace an existing shared library
with an older version! Is it difficult to check version numbers?
A related story about version number checking: just yesterday I was
installing a brand new DVB card (SkyStar2) which gave this error:
"You have XP, service pack 3. You need XP service pack 2 or later.
Windows is out-of-date so installation will terminate." D'oh!!!
Andrew
