[gdal-dev] Parse ISO 8601 formatted timestamps
Frank Warmerdam
warmerdam at pobox.com
Wed Jul 2 07:01:24 EDT 2008
Maarten Plieger wrote:
> Hi,
> Are there existing functions in GDAL to parse ISO 8601 formatted
> timestamps?
> I would like to convert a string of the form YYYYMMDDThhmmss.ss to a
> juliandate and back.
Maarten,
GDAL/OGR has no support (I am aware of) for Julian dates. Most textual
parsing for OGR is encapsulated in the OGRParseDate() function with docs
looking like:
* Parse date string.
* This function attempts to parse a date string in a variety of formats
* into the OGRField.Date format suitable for use with OGR. Generally
* speaking this function is expecting values like:
* YYYY-MM-DD HH:MM:SS+nn
* The seconds may also have a decimal portion (which is ignored). And
* just dates (YYYY-MM-DD) or just times (HH:MM:SS) are also supported.
* The date may also be in YYYY/MM/DD format. If the year is less than 100
* and greater than 30 a "1900" century value will be set. If it is less than
* 30 and greater than -1 then a "2000" century value will be set. In
* the future this function may be generalized, and additional control
* provided through nOptions, but an nOptions value of "0" should always do
* a reasonable default form of processing.
* The value of psField will be indeterminate if the function fails (returns
* FALSE).
* @param pszInput the input date string.
* @param psField the OGRField that will be updated with the parsed result.
* @param nOptions parsing options, for now always 0.
* @return TRUE if apparently successful or FALSE on failure.
int OGRParseDate( const char *pszInput, OGRField *psField, int nOptions )
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
