[gdal-dev] Problems building gdal for win ce
godofredo contreras
frdcn at hotmail.com
Thu Jul 3 12:11:22 EDT 2008
Hi:
Thank you for the patch, it works correctly. I applied to my working copy of
trunk and It compiles without problem.
One more question, I had a problem with function VSI_STAT64
being undefined. I added the following define in src/port/cpl_config.h
#define VSI_STAT64 stat
it compiles, but I am not sure if this is correct or it can
cause some problems later.
Regards
Godofredo Contreras
> From: even.rouault at mines-paris.org
> To: frdcn at hotmail.com
> Subject: Re: [gdal-dev] Problems building gdal for win ce
> Date: Wed, 2 Jul 2008 23:10:26 +0200
> CC: gdal-dev at lists.osgeo.org
> Try the attached patch. Please confirm if it works (I've no WINCE available)
> and I'll commit that
> Index: port/cpl_strtod.cpp
> --- port/cpl_strtod.cpp (révision 14798)
> +++ port/cpl_strtod.cpp (copie de travail)
> @@ -145,6 +145,56 @@
> /* CPLStrtodDelim() */
> +static void CPLReplacePointByLocalePoint(char* pszNumber, char point)
> +#if defined(WIN32CE)
> + static char byPoint = 0;
> + if (byPoint == 0)
> + char szBuf[16];
> + sprintf(szBuf, "%.1f", 1.0);
> + byPoint = szBuf[1];
> + if (point != byPoint)
> + int i = 0;
> + while ( pszNumber[i] )
> + if ( pszNumber[i] == point )
> + pszNumber[i] = byPoint;
> + break;
> + i++;
> +#else
> + struct lconv *poLconv = localeconv();
> + if ( poLconv
> + && poLconv->decimal_point
> + && strlen(poLconv->decimal_point) > 0 )
> + int i = 0;
> + char byPoint = poLconv->decimal_point[0];
> + break;
> + i++;
> +#endif
> * Converts ASCII string to floating point number using specified delimiter.
> @@ -170,30 +220,12 @@
> /* with the one, taken from locale settings and use standard strtod() */
> /* on that buffer. */
> - struct lconv *poLconv = localeconv();
> char *pszNumber = CPLStrdup( nptr );
> double dfValue;
> int nError;
> - if ( poLconv
> - && poLconv->decimal_point
> - && strlen(poLconv->decimal_point) > 0 )
> - int i = 0;
> - char byPoint = poLconv->decimal_point[0];
> + CPLReplacePointByLocalePoint(pszNumber, point);
> - while ( pszNumber[i] )
> - if ( pszNumber[i] == point )
> - pszNumber[i] = byPoint;
> - break;
> - i++;
> dfValue = strtod( pszNumber, endptr );
> nError = errno;
> @@ -263,29 +295,12 @@
> double dfValue;
> int nError;
> - if ( poLconv
> - int i = 0;
> - break;
> - i++;
> dfValue = strtof( pszNumber, endptr );
> nError = errno;
> Le Wednesday 02 July 2008 22:27:31 godofredo contreras, vous avez écrit :
> > Hi:
> > I´m trying to compile gdal for windows mobile, using windows mobile 5 sdk
> > and visual studio 2005 but I´m getting an undefined reference to
> > localeconv in method CPLStrtodDelim and undefined reference to
> > GDALWarpCutlineMasker in method GDALWarpOperation::WarpRegionToBuffer.
> > Have someone had this problems, any idea to solve them?
> > Thanks in advance
> > Godofredo Contreras
> > _________________________________________________________________
> > Don't get caught with egg on your face. Play chicktionary!
> > http://club.live.com/chicktionary.aspx?icid=chick_wlhmtextlink1_feb
Windows Live Hotmail is giving away Zunes. Enter for your chance to win.
http://www.windowslive-hotmail.com/ZuneADay/?locale=en-US&ocid=TXT_TAGLM_Mobile_Zune_V3
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080703/689dd272/attachment.html
