[gdal-dev] a complete list of GDAL supported EPSG codes
    Maciej Sieczka
    tutey at o2.pl
    Sat Jul  5 17:54:37 EDT 2008
Frank Warmerdam pisze:
> Maciej Sieczka wrote:
>> how do I best fetch the list of *real* EPSG codes that my
>> instalation of GDAL is able to recognize? Is extracting them from
>> pcs.csv and gcs.csv a good approach?
> Yes
Cool. I only have a following problem - as I parse the pcs.csv and
gcs.csv like this [1], the following codes:
2218 2221 2296 2297 2298 2299 2300 2301 2302 2303 2304 2305 2306 2307
2963 2985 2986 3052 3053 3139 3144 3145 3173 3295 3410 3993 32600 32700
yield:
ERROR 6: EPSG PCS/GCS code <code goes here> not found in EPSG support
files. Is this a valid EPSG coordinate system?
I expected that a code extracted from pcs/gcs.csv should be valid for
GDAL. What am I missing?
Also, a couple of codes yield:
ERROR 6: No translation for Tunisia_Mining_Grid to PROJ.4 format is known.
ERROR 6: No translation for Transverse_Mercator_South_Orientated to
ERROR 6: No translation for Laborde_Oblique_Mercator to PROJ.4 format is
known.
I found a reference for that [2], so I briefly understand what's the
culprit and that we are just to ignore the problem for now. Out of
curiosity anyway - has there been any progress on the issue?
Maciek
[1]
for i in `awk 'NR>1' /usr/local/share/gdal/pcs.csv | cut -d, -f1`; do
printf "$i "; epsg_tr.py -proj4 $i; done
for i in `awk 'NR>1' /usr/local/share/gdal/gcs.csv | cut -d, -f1`; do
[2]http://lists.osgeo.org/pipermail/gdal-dev/2008-February/016249.html
Maciej Sieczka
www.sieczka.org
