[gdal-dev] coordinate transformation problem in python
Tue Jul 8 12:29:53 EDT 2008
WolfgangZ wrote:
> #target SRS
> tSRS=ogr.osr.SpatialReference()
> tSRS.ImportFromEPSG(31468)
Wolfgang,
When I check what OGR uses for EPSG:31468 I see:
    +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
+datum=potsdam +units=m +no_defs
I see that PROJ defines datum=potsdam as:
      potsdam bessel       towgs84=606.0,23.0,413.0
                           Potsdam Rauenberg 1950 DHDN
> Then I tried it with cs2cs.exe ad the result from there is:
> cs2cs.exe +proj=latlong +datum=WGS84 +to +proj=tmerc +lat_0=0 +lon_0=12
> k=1.000000 +x_0=4500000 +y_0=0 +ellps=bessel
> +towgs84=591.28,81.35,396.39,1.477,-0.0736,-1.458,9.82 +units=m +no_defs
> 12.074760 47.893320
> 4505696.75      5306125.78 -52.43
> I suppose the my python code is ignoring the different ellipsoid. Is
> that behaviour desired? What about other gdal software like gdalwarp?
So in my opinion you are getting different results between cs2cs and
OGR because OGR uses different datum definitions than you are using.
You might be better off uses importFromProj4() instead of ImportFromEPSG()
if you have particular ideas on the datum shift you want to use.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
