[gdal-dev] how to create a latitude map
Frank Warmerdam
warmerdam at pobox.com
Wed Jul 9 09:13:48 EDT 2008
Yann Chemin wrote:
> Hello,
> how would you go to write a GDAL-based code to return latitude (or
> longitude) as pixel values?
Yann,
You are wanting to write this in C/C++?
Loosely speaking I think you need to:
o Create a GDAL GenImgProjTransformer from the image to lat/long.
o Invoke the transformer for each pixel in the image, and record the
results to a new output band/file.
You might look at gdal/apps/gdaltransform.cpp as an example of how to
create an image transformer (a function for transforming from image
coordinates to some other image or georeferenced coordinates).
Invoking a transformer is a bit expensive, so call it on an array of
locations for a whole line, rather than making a call for each pixel.
The following docs may be of help:
http://www.gdal.org/ogr/osr_tutorial.html
http://www.gdal.org/gdal__alg_8h.html#7671696d085085a0bfba3c3df9ffcc0a
Good luck,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
